IP problem
manumanojr
I have a problem. Pls give me a solution
We have 253 pc having ip 10.0.56.1 to 10.0.56.254 ?.classless ip. Now we got 25 more pc?s and another range of ip with 10.2.115.1 ? 254.(classless)
Our agents logged in as power (user name) in enetwork (our domain) is not able to access our dataserver named rainbow but logged in as PC administrator not in the domain (?..this computer) is able to access the dataserver with the new ip (10.2.115.1 )
Our dataserver is accessed by old ip 10.0.56.1 but logged in as domain user having 10.2.115.1 is not able to access the dataserver.....
Can u pls help me by providing the changes that has to be done on our network.
mohammedmahmoud
Level 11
Level 11
Is there a router that routes between these 2 subnets ?
If yes, then kindly post the config.
If no, there should be a router to route between the 2 different subnets.
HTH, please rate if it does help,
Mohammed Mahmoud.
