I try to use IPM 4.0.0 with IE7, I encountered problems with Monitor button, the graph does not appear, so I try whit IE 6 and then I have the graph but nothing to graph only the minutes on the graph.
Plus I don't have anything in the graph?
What's wrong?
I just test the Echo with a router running 12.2 IOS and the target is a switch with rtr responder enable...
