- That issue is 'perimeter-centric' and will 'ONLY" depends on which protocols (ipv4 or ipv6) you are currently using on the perimeter. ipv6 is the sucessor of ipv4. If you no longer need ipv4; the you are on a modern track.
M.
-- ' Listen to the wind, it talks
Listen to the silence, it speaks
Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
