Is it possible to monitor packet drop without any configuration required at ISP end?
Hi All,
Is there any way by which we can monitor packet drop on a internet link without any configuration required at ISP end. Kindly advice. Thanks!
Sunitha
8 Replies 8
Hi Sunitha,
Yes.
IP SLA is your solution.
Smitesh
Hi Smitesh,
Thanks for your quick response. As per my understanding, we need to configure ISP end as IP SLA responder... so this requires configuration at ISP end.
Do you my explaining how this could be achieved.
Thanks!
Smitesh
Hi Sunitha,
Responder is not neccesaarily required.
Lets assume topology as
R1 --- R2 --- R3
We would be running imcp-echo from R1 loopback (1.1.1.1) to R3's loopback (3.3.3.3)
R1#sh run | sec ip sla
ip sla 1
icmp-echo 3.3.3.3 source-interface Loopback0
frequency 5
ip sla schedule 1 life forever start-time now
R1#
R1#sh ip sla statistics details
Round Trip Time (RTT) for       Index 1
        Latest RTT: 71 milliseconds
Latest operation start time: *00:12:41.799 UTC Fri Mar 1 2002
Latest operation return code: OK
Over thresholds occurred: FALSE
Number of successes: 57
Number of failures: 7
Operation time to live: Forever
Operational state of entry: Active
Last time this entry was reset: Never
Now, see the results, when I have shutdown the link between R2 and R3.
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *00:13:41.799 UTC Fri Mar 1 2002
Latest operation return code: Timeout
Number of successes: 68
Number of failures: 8
There are two things to notice,
1. Latest RTT
2. Number of success and Failure.
From which you can deduced whether the packets were dropped or not.
HTH,
Smitesh
Hi Smitesh,
Will try to implement and let you if this works. Thanks again :-)
Sunitha
Hi Smitesh,
Is there any way in which the snmp will trigger only when the packet loss is 80%...
Sunitha
Hi Sunitha,
As far as I know, there is snmp mib for IP SLA (though I don't know those MIB values), which then you  can configure the threshold in your NMS.
Another way you can do it is via EEM.
Unfortunately, I'm not  good in EEM
Smitesh
Hi Smitesh,
I'll search for it. Thanks!
Sunitha
