01-18-2016 06:39 AM
Our NMS was showing 0% free memory. Now when we are running "show memor" it is giving the below output. While following the below
"http://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/memorytroubleshooting/isr4000_mem.html"
document we came to know that if we have lsmpi Free memory stats like below are normal. I want to know how can I poll the "Processor" memory instead lsmpi_io memory ? It look like it is showing me lsmpi stats. Please confirm if I need to download some new MIB for it ?
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 7F4C4BB45010 1728098704 249139136 1478959568 679445864 1048575908
lsmpi_io 7F4C4B4431A8 6295128 6294304 824 824 412
MIB Locator : is showing below MIBs which are memory related. I am not sure how can I move forward. Will I have to upload some new MIB into NMS ?
CISCO-ENHANCED-MEMPOOL-MIB
CISCO-MEMORY-POOL-MIB
OLD-CISCO-MEMORY-MIB
Solved! Go to Solution.
01-20-2016 12:13 PM
Load the output into a text editor. Search for the most significant digits of the free memory. You should find one entry, and that is it.
01-18-2016 10:25 AM
Perhaps try an snmpwalk and look for OIDs with about the same numbers as above?
01-20-2016 03:32 AM
There are hundreds of option under "1.3.6.1.4.1.9.9.221." How can I found the OID for exact
"Free Processer memory" ?
01-20-2016 12:13 PM
01-20-2016 09:08 PM
Thanks I got that.
