ISR4331 UCSE Compute Module, is PXE HTTP Boot Possible?
pakmon1722
I've been able to successfully setup TFTP boot with the UCSE module through PXE boot, but I cannot seem to get PXE HTTP boot to work.
I have the HTTP server setup correctly on the 4331, I can browse the default file in pxelinux.cfg directory, but no matter what settings I change, setting DHCP option to 210 with url, or changing the default file, It always tries to boot with TFTP.
Is this because the PXE capabilities on the hardware doesn't have the underlying iPXE capabilities? Does anyone have any experience with this?
I figure it's a longshot but worth a try to ask. Not only myself but others on my team have put a significant amount of time against this problem and can't seem to nail it down.
Thank You
0 Replies 0
