Issue With PRIME ASSURANCE
Liad Dayan
Hi guys,
I want to download a demo from Prime Assurance for my customer for impression  .
Now when i want to get the demo it say:
Product ID:
Serial #:
When i go in the CLI and type "show udi"
I get
SPID:CISCO-VM-SPID
VPID:V01
SERIAL:H96QI4FESGO
When i generate the UDI and try to put it on the PAM, it says UDI is not match to the system UDI.
So i try to get the information from the web:
in the web it say:
Type Unlicensed
VUDIPRIME-NCS-VAPL:Cisco-Prime:e8387b90-b3af-11e1-96f2-0050568c0063
Product IdPRIME-NCS-VAPL
Serial NumberCisco-Prime:e8387b90-b3af-11e1-96f2-0050568c0063
Even when i put this in the generate and get a new key it still say " UDI is not match to the system UDI".
Somone know what might be the issue?
Same issue, NCS 1.1
Caveats Associated with Release 1.0.2.29
Table 6 lists  the open caveats in NCS Release 1.0.2.29
Table 6 Open  Caveats
ID Number
Caveat Title
CSCtr57972
The UDI information from CLI and NCS UI does not match.
Symptom: The UDI information obtained from  CLI does not match what appears in the NCS GUI. The CLI value is not correct for  licensing or identifying the NCS.
Conditions: Any CLI command that displays  the UDI of the virtual machine is displaying the incorrect value.
Workaround: Only use the UDI displayed in  the GUI for licensing or identifying the NCS.
I'm trying with the last 1.1.1.24, without sucess too.
