Issues configuring FTP logs for CISCO ASA 5506X
Peter Brady
Hi all,
I am trying to setup my ASA to export buffer logs an an FTP server. So far I have
  1. Setup and FTP server and tested it, with a dedicated user and location for the ASA.
  2. Configured the exporting of logs via the ASDM (Configuration -> Device Management -> Logging -> Logging Setup -> Configure FTP Settings...) with the details:
    • SERVER IP: XXX.XXX.XXX.XXX
    • PATH: /
    • USERNAME: <username>
    • PASSWORD: <password>
    • CONFIRM: <password>
Now it isn't working. So as my next step I tried sending an individual file to the serve rusing the command line (via the ASA). I tried this command:
  • copy disk0:/startup-config ftp://<username>:<password>@XXX.XXX.XXX/
But I am getting this result (and yes, startup-config appears when I do dir disk0:/) :
  • Source filename [startup-config]?
    ?Bad filename
    %Error parsing filename (No such device)
So yeah I'm a bit lost. As a followup, is this the best way to do FTP logging from an ASA, or is there something better? This just seemed like the simplest.
Thanks!
marce1000
 - As far as the test with the startup-config some suggestions 1) Append a target-filename-destination to the end of the command too 2) Have a test with disk0:/ removed from the copy command 3) To check if the error relates to the behavior of the FTP server or not , check it's logs when this is tried. In that way it can be verified if the ASA made a connection to the FTP host or not.
 M.
Hi @marce1000 thanks for the response, I have tried as you suggested.
1) Tried doing that, includinng after trying steps in 2 & 3, with no result.
2) This did make a difference. So with my new command:
copy startup-config ftp://<username>:<pw>@<ip-address>/startup-config
I got this in response
Address or name of remote host [<ip-address>]?
?Bad address or host name
%Error parsing filename (Invalid argument)
I also tried using the hostname. This would sometimes give them same error as above, but then would also sometimes give this error:
Address or name of remote host [<hostname>]?
%Error parsing filename (Resource temporarily unavailable)
I also read somewhere that adding the interface at the end might be necessary (appending ;int=<interface-name> to the command) but this didn't change anything.
3) I increased the logging level so that it logs the entire FTP protocol. Nothing is logged when the command are sent from the ASA.
 - Check current software version being used, if it's old - upgrade to a recent release. Check if the problem persists afterwards.
 M.
