Issues with VMS IDS database
jdelrosario
All,
I am trying to access my IDSM2 module within VMS so that I can look at and purge events. I keep getting the following error:
IDSSystem unable to create SQL Statement: null.
I've tried to add my sensor, but CW is saying that it already exists... should I just try and delete the sensor and add it again???
I had to unistall Campus Manager 3.1 because it was conflicting with my VMS 2.2 database... Right now, I have RWAN and VMS on the same box...
amritpatek
Level 11
Level 11
1) If you have restored database recently, then do a restore again.
2) If you don't have much free space in the drive where database is running, then do some maintance tasks as mentioned in the below document.
http://www.cisco.com/en/US/products/sw/cscowork/ps3991/prod_maintenance_guide09186a00801cb53f.html
