LAN edge view
cmartinvalle
we have a LMS 3.0.1 over Windows. In Topology Services, 2 groups (switch-clouds) appear related to the same subnet and we don't understand the reason. They should belong to one only switch-cloud.
Can anyone explain me if this behaviour is correct? And if not, how could we fix it?
Thank you very much.
Joe Clarke
In order to know if the behavior is correct, I'd have to see the topology. A switch cloud is two or more switches directly connected without a router in between them. Routers make up the perimeter of switch clouds.
