Large buffer memory OID
kinmuntang
Hi All,
Got to know from my colleague that below IOS and MIB are running on modular IOS (VZ image), hence, the SNMP objects ciscoMemoryPoolUsed and ciscoMemoryPoolFree report specifically on the 'ios-base' statistics as is seen in the output of "show memory detailed ios-base statistics”, and not the total processor and I/O memory available in the system. In fact, this is an expected behavior in modular IOS,
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.896 (s72033-ipservicesk9_wan-vz.122-33.SXI7)
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.657 (s72033-ipservicesk9_wan-vz.122-33.SXI2)
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.832 (s72033-ipservicesk9_wan-vz.122-33.SXI2)
However, does anyone know the exact OID for 'Large buffers' in Public buffer pools?
Show buffers
Switch#sh buffers
Buffer elements:
     495 in free list (500 max allowed)
     1613438366 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
     943 in free list (128 min, 2048 max allowed)
     225564301 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Medium buffers, 256 bytes (total 3000, permanent 3000):
     2997 in free list (64 min, 3000 max allowed)
     1364429398 hits, 0 misses, 0 trims, 0 created
Middle buffers, 600 bytes (total 512, permanent 512):
     502 in free list (64 min, 1024 max allowed)
     1059385296 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 1000, permanent 1000):
     992 in free list (64 min, 1000 max allowed)
     779183877 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 12 @ 7w0d):
     10 in free list (0 min, 100 max allowed)
     6716997 hits, 13 misses, 6 trims, 6 created
     13 failures (0 no memory)
Large buffers, 9240 bytes (total 8, permanent 8):
     8 in free list (0 min, 10 max allowed)
     22562420 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 2, permanent 2, peak 10 @ 7w0d):
     2 in free list (0 min, 4 max allowed)
     319767 hits, 13 misses, 26 trims, 26 created
Many thanks,
Tang
0 Replies 0
