LDAP supports on catalyst switch for CLI admin (exec) authentication
michaelzhq
Level 5
Level 5
Does IOS on catalyst switch support LDAP authentication for CLI admin (exec) login ? I've checked numerous configuration guides, but couldn't find a clear answer.
Thanks!
Mark Elsen
   I found several references if I google on :
               cisco switch ldap authentication
  But it seems that it works only for recent IOS or XE versions.
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Marvin Rhoads
Cisco ISE as the TACACS+ server would be the way to go.
It can use LDAP (among others) as the backend identity store.
That will be compatible with any devices that supports either TACACS or RADIUS AAA servers ( I.e. almost any managed Cisco IOS-based device).
