LMS 2.2
ahmed_saleh
LMS 2.2 can support 2800&1760 router or no
Joe Clarke
LMS 2.2 is end of life and end of support. You need to upgrade to LMS 2.6 or higher. The latest versions of LMS do support the 2800 and 1760 series routers.
That said, LMS 2.2 with the appropriate IDUs also support these routers. Here is the RME 3.5 support list:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/3.5/device_support/table/e3_5.html
