LMS 2.5.1 (RME)
When i try to update the configuration from RME->Config Mgmt->Config Editor->
Config Editor Jobs. The running configuration becomes updates but not the startup one. i got this message from Config Editor "Deploy succeeded, Synchronization of RME archive with Device Config failed" with the Failed Status
pl. help me to resolve this issue.
miheg
Level 5
Level 5
So it seems you deployed a new running config.
It's an option in the job to do a write and sync to the startup config.
Or you run a second job to sync all configs that have a different startup and running config.
Cheers,
Michel
Yes, i want to use the option in the job to do write n sync to the startup config.
The job status is failed and i got this message
