LMS 2.6 remote configuration
shijuuu
i am new to CW LMS2.6 somebody help me to push the configuration into multiple cisco devices
thanks.
Joe Clarke
Assuming you want to push a small configuration change to a large number of devices, you use the RME Netconfig tool for that. Go to RME > Config Mgmt > Netconfig > Netconfig Jobs, and create a new job. Select the devices to which you want to deploy the changes, then select the configuration templates. See the context-sensitive online help for more details about what each template provides.
thank u very much
it helpd me.
