LMS 3.0.1 / RME : unable to subscribe syslog collector
ebezombes
Customer has LMS 3.0.1. syslog reports are empty.
When we look at RME->tools->syslog->collector status:
all colums are N/A except Name: LMS hostname and Update time : Not Reachable.
Both SyslogCollector and SyslogAnalysor are running:
Process= SyslogAnalyzer
State = Program started - No mgt msgs received
Pid = 9576
RC = 0
Signo = 0
Start = 03/10/2008 12:16:01
Stop = Not applicable
Core = Not applicable
Info = Server started by admin request
Process= SyslogCollector
Pid = 19616
RC = 0
Signo = 0
Start = 03/10/2008 12:13:58
We have verified that LMS server received syslog with a sniffer.
We unsubscribe collector, after we try to subcribe, but it fails with this message:
SLCA0126: Could not subscribe to the Collector.
1.Check whether the collector is running.
2.Make sure that SSL certificates are imported/exported correctly and process restarted.
3.Check whether the Certificates exported/imported are valid and have not expired.
4.Check whether SyslogAnalyzer process is running.
Thanks, Elisabeth
Here, you can find logs with debug.
10 Replies 10
ebezombes
log files
Two problems I see. One, the server appears to be localized for French which is not supported. You must change the server's localization to US English. Second, it appears another application is occupying tcp/4444. If you shutdown Daemon Manager, and look at netstat -a -n -o -b, you can see what application this is. If that application is shutdown, and Daemon Manager is restarted, syslog analysis should begin to work.
Hi Joe,
Many thanks for your response, port 4444 was not available ! Best regards, Elisabeth
hi ebezombes,
i am facing the same problem excatly
port 4444 is not available,what did you do after that?
thanks in advance
regards
Your two choices are either to free up tcp/4444 on the server so that SyslogAnalyzer can use it, or change the value on NMSROOT/MDC/etc/regdaemon.xml. Replace 4444 with another free TCP port value. Make sure you backup regdaemon.xml before making any changes.
After making the change, restart Daemon Manager.
hi again
i replaced 4444 with 48889 TCP port(NMSROOT/MDC/etc/regdaemon.xml) but still facing the same problem
do you have any other options?
regards
You should start a new thread for your issue.
Thanks for your response but i have one more questions,after changing the ports,i followed the following path:C:/PROGRA~2/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\C:\PROGRA~2\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data
\Collector.properties"
and i noticed that the COLLECTOR_PORT=4444
do u think i need to change this too?
i have another cusotmer with same configurations but the syslog is working just fine.
regards
Yes, this port must be changed, too, to match the port in regdaemon.xml.
Any other things to change?before i apply it
