LMS 3.0 Campus Manager issues
tverhoeven
I am getting the following message when trying to use CW Assistant.
CDP Neighbors (Could not fetch CDP Neighbor for the selected device.)
CWA27: CiscoWorks Assistant does not support the installed Campus Manager version.
Loading...
Discrepancy (Could not find discrepancy for the selected device.)
Loading...
DFM Alerts (Alerts not retrieved)
CWA28: CiscoWorks Assistant does not support the installed Device Fault Manager version.
I installed LMS 3 last week from scratch and then did the updates from Cisco.
any ideas???
thanks
tony
akemp
Level 5
Level 5
Blatently stolen from Joe Clark:
This is known bug CSCsk19350. A patch is available from http://www.cisco.com/cgi-bin/tablebuild.pl/cwa10 to fix it.
You can use the search function in the forums to find the answers lots of times.
