LMS 3.0 multiserver cluster upgrade, yech!
akemp
Level 5
Level 5
When you upgrade a LMS cluster unfortunately it maintains the old application registrations from the previous version along with the current version on the master server. Clutter!
Ok to clean up the master server I just deleted all application registrations and am now trying to add them back just as was possible in previous versions. Things are a bit different as each hostname for application has to unique now.
So has anyone else encountered this ?
Joe Clarke
I'm not sure I understand why this is a problem. Each server in your network should have a unique hostname.
