LMS 3.0 Solaris 10 Installation Path Question
frankzehrer
Level 4
Level 4
Hi everybody,
i have a Solaris 10 Box (Full Install - with all Java stuff - silly eh?) and a LMS install in /lms/CSCOpx.
So far ok.
Now there is s symbolic link /opt/CSCOpx leading to /lms/CSCOpx.
Please take a look into the system variables.
Soething messed up here.
Can this cause some strange behavour with e.g. Topology Services??
ALIAS=dmgt CSCOmd
ARCH=sparc
ASANY=/opt/CSCOpx/objects/db
ASTMP=/var/adm/CSCOpx/files/.SQLAnywhere
BASEDIR=/opt
BUILD_ID=SOL_CS311_INCR_UPDATE_20071205_1735_protopackage
BUILD_NUMBER=284
CATEGORY=application
CLASSES=pxdm
CLASSPATH=/lms/CSCOpx/lib/classpath:/lms/CSCOpx/www/classpath:/opt/CSCOpx/campus/lib/classpath:/opt/CSCOpx/campus/www/classpath
CORE_NONSECURE_PORT=1741
CORE_SECURE_PORT=443
CWMIBDIR=/opt/CSCOpx/objects/share/mibs
DEBUG=0
DESC=CiscoWorks Process management commands and interfaces DMGT_PORT=42340 DMGT_START= EMAIL=tac@cisco.com HOME=/opt/CSCOpx
HOTLINE=1-800-553-6387
INSTDATE=Feb 01 2008 18:32
I_CONF_SYSLOG=YES
I_MODE=NEW
JAVA_HOME=/lms/CSCOpx/lib/jre
LANG=C
LC_ALL=C
LC_COLLATE=de_DE.ISO8859-1
LC_CTYPE=de_DE.ISO8859-1
LC_MESSAGES=de
LC_MONETARY=de_DE.ISO8859-1
LC_NUMERIC=de_DE.ISO8859-1
LC_OS=sol
LD_LIBRARY_PATH=/lms/CSCOpx/objects/db/lib:/lms/CSCOpx/lib:/opt/CSCOpx/MDC/lib:/opt/CSCOpx/campus/lib:/opt/CSCOpx/campus/lib
MAX_RAM=2048
MAX_SWAP=4096
NAME=CiscoWorks Process Management package NLSPATH=/opt/CSCOpx/objects/share/nls/C/%N.cat
NMSROOT=/opt/CSCOpx
OAMBASE=/usr/sadm/sysadm
ODBCINI=/opt/CSCOpx/.odbc.ini
OS=SOL
OSAGENT_PORT=42342
PATCHVER=1
PATH=/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin:/usr/sbin:/usr/bin:/usr/etc:/usr/ucb
PKG=CSCOmd
PKGINST=CSCOmd
PKGOWNER=NMCihF78oLBcwNg
PKGSAV=/var/sadm/pkg/CSCOmd/save
PRODNAME=CiscoWorks Common Services
PRODVERS=unassigned
PSTAMP=nmch-build-sol28-00620071206131214
PX_ANI_PORT=42344
PX_APPDIR=/opt/CSCOpx/objects
PX_BINDIR=/opt/CSCOpx/bin
PX_CGIDIR=/opt/CSCOpx/cgi-bin
PX_CGIURL=/cgi-bin
PX_CLASSDIR=/lms/CSCOpx/www/classpath
PX_CLASSURL=/CSCOnm/classpath
PX_CONFDIR=/opt/CSCOpx/conf
PX_CTRBDIR=/opt/CSCOpx/contrib
PX_DATADIR=/var/adm/CSCOpx/files
PX_DATASTORE=dsn
PX_DMGTHOST=127.0.0.1:42340
PX_DMGT_PORT=42340
PX_DOCDIR=/opt/CSCOpx/htdocs
PX_DOCURL=/
PX_FACILITY=local0
PX_FQDN=argos.rz.uni-potsdam.de
PX_GROUP=casusers
PX_HLPDIR=/opt/CSCOpx/help
PX_HOST=argos
PX_JRN_PORT=42343
PX_LIBDIR=/opt/CSCOpx/lib
PX_LOGDIR=/var/adm/CSCOpx/log
PX_LOGFILE=/var/adm/CSCOpx/log/dmgtd.log
PX_OSA_PORT=42342
PX_PORT=1741
PX_PROTOCOL=http
PX_SCLASSDIR=/lms/CSCOpx/lib/classpath
PX_TMPDIR=/tmp
PX_USER=casuser
PX_WEB_PORT=1741
SATMP=/var/adm/CSCOpx/files/.SQLAnywhere
SINGLEINSTALLER=FALSE
SQLANY=/opt/CSCOpx/objects/db
SVC_ENTRY_DMGT=cscomd
SVC_ENTRY_JRN=
SVC_ENTRY_OSA=cscoosa
SVC_ENTRY_SSL=cscoapch_ssl
SVC_ENTRY_WEB=cscoapch
SYS_CPU=1504
SYS_NO_OF_CPUS=2
SYS_RAM=4096
SYS_SWAP=5476584
TZ=Europe/Berlin
UPDATE=yes
VENDOR=Cisco Systems, Inc
VERSION=3.7
Many thanks in advance
Frank
Joe Clarke
What do you think is messed up? What problems are you seeing with Topo?
Note: a mix of realpath/symlink path objects is normal in a custom installation. It looks strange, but it has not been known to cause any problems. One thing that could cause problems is your locale being set to German instead of US English or Japanese.
Hi Joe,
many thanks for your reply.
I came in doubt about this cause of several things:
1. The mdcsupport told me everytime that another instance of mscdsupport is running (which was not true) or the path /opt/CSCOpx/MDC/etc/mdcsuppottemp already existed. But i meantime i figured out that the costumer geve my user not root but even casusers rights. Maybe this is the problem.
2. In Topo View are some direct links between devices not straight connected. They are wrinkeld - like another devie is in the path. Whih is not and there is no icon shown in the wrinkle.
3. Path Analysis: In Path Analysis the VLAN Mapping lasts very long to open. Round about 15 Minutes. The Discovery took much longer. And even longer if a had checked the DNS Option.
4. In DFM in the DDV the Interfaces for the 6500-series are not shown. The ports are ok, but the interfaces not. I have hot an jsp-failure yesterday. I will post this in round about 90 Minuten, when i am on my workdesk.
So i was not sure if this behaviour could have benn caused from the symlink.
I konw that for normal the symlink does not affect the behaviour of an application.
But in the past i had problems with an Java environment and symlinked paths.
Thanks a lot for your time and valuable help here in the forum.
Best reagrds,
Frank
P.S. I will fix the locales - of course
