LMS 3.1 Campus Manager 5.1.0 - ANIServer process trouble
gary.whitaker
No matter what i do i just cant seem to get the ANIServer process to run. I have even restored the campus manager DB.
Please please help. thank in advance
The ANIServer.properties is completely corrupt. Copy NMSROOT/campus/etc/cwsi/ANIServer.properties.orig to ANIServer.properties. Then modify the file, and change the DEVICESROOT line to read:
DEVICESROOT=NMSROOT\\campus\\lib\\classpath
Where NMSROOT is the path into which LMS was installed (e.g. C:\\PROGRA~1\\CSCOpx). Also, change the AniName line to:
AniName=ANIServer6.0-boe-ciscoworks2
After that, ANIServer should start.
8 Replies 8
Joe Clarke
Please post the ANIServer.log and the ani.log.
Attached aniserver.log but the ani.log is 6mb so i have only attached the latest information which was in it.
thanks
It appears you have a few problems. First, check the permissions on d:\PROGRA~1\CSCOpx\campus\etc\cwsi\ANIServer.properties. Make sure the casusers group has full control to this file, and all parent directories. Second, the ANI database appears to be down. Please post the output of the pdshow command.
The casuser has full rights to the file and all of the D: in fact
D:\Program Files\CSCOpx\campus>pdshow ANIServer
Process= ANIServer
State = Failed to run
Pid = 0
RC = -1
Signo = 1073741823
Start = N/A
Stop = 12/16/2008 4:25:57 PM
Core = Not applicable
Info = Application failed or was registered incorrectly.
I wanted to see the entire pdshow output. Additionally, please post NMSROOT/campus/etc/cwsi/ANIServer.properties.
Apologies please find attached
much appreciation, your a genius :)
