LMS 3.1, Device Center shows HUM@oldserver in Managing Applications
NBADADMINs
1st we have Ciscoworks LMS 3.0 on server name : svctag-h935b2
2nd back and restore Ciscoworks LMS 3.0 on new server with name CiscoWorks with no error and follow up cisco docments
3rd we upgrade to Ciscoworks LMS 3.1 and have 3 issues
Issue one : CWA038: End Host / IP Phone workflow does not support the version of Campus( Solved by TAC)
Issue Two : Device Center shows HUM@oldserver in Managing Applications ( still not solved)
Issue Three : Tools------- Syslog---- Syslog Collector Status ---- has oldserver at Collector Status and can't unsubsribe it
with error
SLCA0135: svctag-h935b2j could not be unsubscribed.
Check whether the Collector is running.( still not solved)
Your early response will be highly appreciated. For any further inquiries, please don’t hesitate to contact us.
Best Regards
Muhammad F Essa
Network Administrator
Information Technology Department
National Bank of Abu Dhabi - Egypt
Tel: +2 02 37475217
Mob: +2 0117774415
Fax: +2 37475299
Joe Clarke
All of these issues are unrelated.  I will address the first issue here.  You can start new threads for the other two issues.  This first issue is a bug, and TAC can provide you the patch to correct it.  You will need to open a service request to get the patch.  The patch will update the CWA engine to understand the current version of Campus (and DFM).
Joe Clarke
thanks Joe
for  the first issue
I already open TAC and TAC team solved it
For 2nd and 3rd I started new threads for the two issues
