LMS 3.1 Devices not selectable in RME
NBADADMINs
LMS 3.2 Devices not selectable in RME
Running LMS 3.1 RME 4.2.0   when trying to do any tasks at Config Mgmt or Software Mgmt I am not able to select any device in the Device selection window.
Make sure the Common Services MDF is the same version on all servers in the master/slave cluster.  The current latest version is 1.40.  Go to Common Services > Software Center > Device Update, check the box next to Common Services, and download and install the same MDF version on all servers.  Then see if the problem persists.
6 Replies 6
Joe Clarke
This is most likely due to an RME package problem.  Post the RMEDeviceSelector.log, dcmaclient.log, NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
Dear Joe,
     please find attaced files.
Is this a master/slave DCR setup?
MASTER DCR setup
many thankx now everythings works fine
