LMS 3.1 on Solaris 10 - Reset all databases to initial state
josefribeiro
Is there a script that would clear all databases for LMS 3.1 on Solaris 10?
I imported do CS some devices from a CSV file I exported from an old LMS 2.5 server we had. I get some very strange results when I ask to sync archive for instance. The devices I manually added work fine, but the ones I imported get stuck and the job takes forever to finish (10 hours in some instances, for 230 devices).
I'd like to re-start from scratch without having to uninstall and reinstall LMS.
Jose Ribeiro
MGS
Joel Monge
See this DOC for the commands to reinitialize all databases.
Joel Monge
Thanks, Joel. That's exactly what I was looking for.
Jose Ribeiro
