LMS 3.1 Upgrade Errors
rajesh_san
Community Member
Installing LMS 3.1 on existing server running 3.0 gives error message stating unable to backup old configs data from version 3.0
The backuplog displays the following error messages. RME Database backup and other components completed successfully except this one.
Not enough memory to start
Validation D:/LMS30/AUTOMA~1/CMFBAC~1\0\upm\database\upm.db failed.
ERROR(1083): Database upm backup failed and . Check the log file for information.
Backup failed:
Win 2003 SP2 Server with 6 GB RAM.
I'd appreciate any help in solving this.
Thanks in advance
Joe Clarke
This could point to a corrupt HUM database. How big is this database file?
Hi Joe, The file is around 70GB.
I suggest you open a TAC service request so development can investigate this. I'm not sure how big of a HUM database they tested with, or in what environment. You may have hit a capacity issue.
