LMS 3.1 Windows - Installation Problem
tckoon
I am having problem to run the installation. After insert in DVD media, the installation windows pop up. When I click on "install" , after a while error message pop up.
I dont know why what what the message mean.
I also check on Windows event log... it complaint about CD problem with paging error.
Lucien Avramov
Level 10
Level 10
It sounds to me that your DVD media got damaged. You may contact TAC to get a replacement.
I suspect the DVD drive problem. I try in my home PC, the installation can be run properly.
I would give a try to copy the DVD contents to my USB HDD, then transfer installation files/directory to server via this USB external drive.
Question is can installation really run from local HDD.
Regards.
Yes, but you need to do the installation from a patch which meets local DOS 8.3 filename convention. For example, if you install from C:\LMSDVD, that should be fine.
