11-20-2013 07:46 AM
I am using LMS 3.2.1 and unable to do the Software Repository job via RCP, because of the below error message.
Problem:
SW1#copy flash1:c2960s-universalk9-mz.150-1.SE.bin rcp://cwuser@CW-IPAddress:/CSCOpx/temp/rep_sw_4972128000394429365
Address or name of remote host [CW-IPAddress]? CW-IPAddress
Destination username [cwuser]? cwuser
Destination filename [D:/CSCOpx/temp/rep_sw_4972128000394429365]? D:/CSCOpx/temp/rep_sw_4972128000394429365
Writing D:/CSCOpx/temp/rep_sw_4972128000394429365
%Error opening rcp://cwuser@ CW-IPAddress /D:/CSCOpx/temp/rep_sw_4972128000394429365 (Undefined error)
LDNW-STKT-F00-SW2#copy flash1:c2960s-universalk9-mz.150-1.SE.bin tftp:// CW-IPAddress /rep_sw_1225718452630721792
Destination filename [rep_sw_1225718452630721792]?
SW1#
In the device, below are the rcp configurations
ip rcmd rcp-enable
ip rcmd remote-username cwuser
And also in the CS->Server->Admin->System Preferences, RCP user is configured as cwuser. Please advise, if I need to configure it some other settings.
Attached is the software deployment preferences.
Question:
Although CiscoWorks can successfully do the Inventory Collection and Sync Archive job of the same device.
Also as you can see above CiscoWorks can do Software Repository job via TFTP. As TFTP is not reliable, RCP is TCP protocol, I want to use RCP.
Please advise that why RCP is failing and how I can correct the RCP issue.
11-23-2013 01:49 PM
This issue is resolved itself by rebooting the CiscoWorks Server.
