LMS 3.2.1 with WS-C4500X-16 (Supported Device)?
Dawit Zeru
is the device WS-C4500X-16 Supported in LMS 3.2.1?
i tried to serch it in the Supported Device Table for LMS 3.2, but i didnt found the exact module (4500x).
here are the link for the:
thanks
dawit
Mahabir Prasad
Hi Dawit
Do you have device available with you? If yes then it will be better if you can check sysObjectID (1.3.6.1.2.1.1.2)
of device and then check in supported device table.
It always good to check device support with sysObjectID for accuracy.
Mahavir
