LMS 3.2 and Cisco Nexus 5K
alkabeer80
Hi, i have problem with lms 3.2 and Cisco Nexus 5020 Switch.
i add the nexus manually on AAA and on LMS, when i go RME  Collection status i find error on both Inventory and config archive
Devices for which Inventory has never been  collected, i run the inventory many times and i always get this error.
Another question:
can LMS discover devices automatically, or each time i need to install new device i have to add it to lms ?
thanks
nawas
Level 4
Level 4
What VDC does not do invenvoty collection and config archive?
If you are running 4.x version there is a lack of support of ENTITY-MIB which is addressed in the 5.x version of code.
LMS can discover device automaticall, check your discover setting under common services. Make sure you have device discover enabled and seed devices defined.
