LMS 3.2 - Backup hangs with validating ANI-DB
lo.mueller
Hello all,
on our Solaris Systems running LMS 3.2 backup struggles with backing up ANI-DB (even after doing Restore of orig db).
As the problem arises on more than one LMS 3.2 system with same patch-level my question
to you -> is this a known problem?
Thanks for any feedback
Lothar
Here's the point when backup results in freeze
(dbbackup.log)
[Mon Mar 29 11:32:01 2010] Archiving the contents of the following directories into /enbw/backup/files/cw_db_backup_nfs/4/campus/filebackup.tar
[Mon Mar 29 11:32:01 2010] /opt/CSCOpx/campus/etc/cwsi/DeviceDiscovery.properties
/opt/CSCOpx/campus/etc/cwsi/ANIServer.properties
/opt/CSCOpx/campus/etc/cwsi/ut.properties
/opt/CSCOpx/campus/etc/cwsi/discoverysnmp.conf
/opt/CSCOpx/campus/etc/cwsi/datacollectionsnmp.conf
/opt/CSCOpx/campus/etc/cwsi/WlseUhic.properties
/opt/CSCOpx/campus/etc/cwsi/UTSnmpv3EngineParam.txt
/opt/CSCOpx/campus/etc/cwsi/UTDiscoverOnTrunk.properties
/opt/CSCOpx/campus/etc/cwsi/users
/opt/CSCOpx/campus/etc/cwsi/archives
/opt/CSCOpx/campus/etc/users
/opt/CSCOpx/campus/etc/cwsi/ReportArchives
/opt/CSCOpx/campus/etc/cwsi/CMReportArchives
/opt/CSCOpx/campus/etc/cwsi/portsData.xml
/opt/CSCOpx/campus/etc/cwsi/RouterData.xml
/opt/CSCOpx/campus/etc/cwsi/vlanData.xml
/opt/CSCOpx/campus/etc/cwsi/CMHP.properties
/opt/CSCOpx/campus/etc/cwsi/MACDetection.properties
/opt/CSCOpx/campus/etc/cwsi/OUI.properties
/opt/CSCOpx/campus/etc/cwsi/PortModuleConfig.properties
/opt/CSCOpx/htdocs/campus/maps
/opt/CSCOpx/campus/lib/classpath/com/cisco/nm/cm/ut/uhic/utlite/properties/utliteuhic.properties
/opt/CSCOpx/campus/lib/classpath/com/cisco/nm/cm/ut/utm/properties/utm.properties
/opt/CSCOpx/campus/lib/classpath/com/cisco/nm/cm/ut/uhic/mac/properties/macuhic.properties
/opt/CSCOpx/campus/etc/cwsi/vnmData.xml
/opt/CSCOpx/vnm/conf/VNMServer.properties
/opt/CSCOpx/vnm/conf/VNMClient.properties
/opt/CSCOpx/vnm/conf/velocity.properties
/opt/CSCOpx/vnm/conf/VRFCollectorSnmp.conf
/opt/CSCOpx/vnm/reports/VNMReportArchives/archives
/opt/CSCOpx/vnm/reports/VNMReportArchives/jobs
/opt/CSCOpx/bin/tar: Removing leading `/' from absolute path names in the archive
mkdir /enbw/backup/files/cw_db_backup_nfs/4/campus/database/
[Mon Mar 29 11:32:11 2010] Backing up database aniDb:SQL Anywhere Command File Hiding Utility Version 10.0.1.3830
SQL Anywhere Backup Utility Version 10.0.1.3830
(3348 of 3345 pages, 100% complete)
Database backup completed
Joe Clarke
At this phase, the backup is trying to verify the database.  When that hangs, it typically means the database is corrut in some way.  It could also point to a very large ANI database, and this phase is just taking a long time.  It also looks like you're trying to backup to an NFS mount.  Can you try a backup to a local file system, and see if the verification completes?
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Hi Joe,
thanks for your feedback.
Do you have any experiences with doing backups with Sybase over NFS-Shares (NFS-Share will be mounted with automounter)?
Are there recommended/best practise settings/NFS-Options?
Doing backup directly to NFS-Share would be first choice for our backup-mgmt (centralized NAS).
Best Regards
Lothar
We recommend customers do a backup locally, then move the backup directory to a network-attached file system.  For example, you could wrap the backup.pl script to run the backup, then copy the resulting directory if the backup runs completely.  This approach is safer because if the copy operation fails, you still have a good local copy.
