LMS 3.2 compatibility with 2008 AD
mangesh.kamble
Dear All,
Another issue faced by my team.
We managed to install LMS 3.2 succesfully and all devices were reachable through LMS.
We have AD present in our network, but whenever the request goes for AD authentication we are not able to succed in it.
We feel there is compatibility issue with AD 2008 rel. 2 and LMS 3.2
We know that LMS 3.2 is not compatible with 2008 rel. 2 for installation.
Request for your valuable inputs.
Mangesh.
Vinod Arya
We have incompatibility with Win 2008 R2 due to the DFM code not compatible with that version.
I dont think there should be an issue of  AD on Win2k8R2.
Please check the configuration document for Changing Login Module to MSAD.
Also, if you have a ACS box, you can try integrating ACS with ciscoworks and have ACS using the MSAD Db.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
