LMS 3.2 not forwarding SNMP Traps
scott_matthews
I am using LMS 3.2 and under DFM... Notification Services... SNMP Trap Notification, I have a Subscription set up to forward Traps to Unicenter 11.1.  I have tried a combination of sending Alerts and Events, Critical and Informational, Active and Cleared messages.
At this time I have it set to send:
Alerts Informational and Cleared
Events Critical and Informational, Active and Cleared.
Every Trap that is forwarded from LMS I get in the Unicenter console Twice.   Also, I occasionally get a clear in Unicenter, but normally clears are not being forwaded.
Any ideas on this issue?
-Scott
Joe Clarke
You should first install the consolidated DFM 3.2 patch from http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=3.2.0&mdfid=282640771&sftType=CiscoWorks+Device+Fault+Manager+Patches&optPlat=Windows&nodecount=2&edesignator=null&modelName=CiscoWorks+Device+Fault+Manager+3.2&treeMdfId=268439477&treeNa... (patch for CSCta56151).  If the problem persists after that, post the NMSROOT/log/dfmLogs/NOS/nos.log after reproducing the problem with a new event/alert.
