LMS 3.2 Remove existing and RE-Discover
davepeat2
Beginner
Beginner
I have CiscoWorks LMS 3.2. Our Network has changed drastically and I want to get rid of everything and do a re-discovery with only certain subnets, most of them being a /23. Does anyone know the best procedure to accomplish this?
Thanks in advance!
AFROJ AHMAD
Hi ,
Since you are using LMS 3.2 , if you remove all the device from CS (commmon service ) this will remove all the devices from other application like DFM , RME , Campus etc...
so it would be like a fresh install , are you really want to do this ...?
For device discovery option , you can't run the discovery on a particular subnet ,if you want some specific subnets not to be discovered then you can use the EXCLUDE or filter setting to exclude them.
for more details , you can check the below link::
https://supportforums.cisco.com/document/33526/understanding-lan-management-solution-lms-discovery
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Recognize Your Peers
