LMS 3.21 rebuild Patch install
Ian Beck
I am rebuilding my LMS 3.21 and try to install relevent patches and have hit the following impass and just need to know if it is ok to install patch 46847 ?
D:\Updates\LMS_321_Update\CS\cwcs33-win-CSCtj01051\CSCtj01051-0>d:\ciscoworks\bin\perl CSCtj01051-0.pl
The patch is getting installed.....
You do not have the mandatory patch CSCtg46847-0 installed
Kindly install Openssl 0.9.8n patch(CSCtg46847-0) before this patch.
D:\Updates\LMS_321_Update\CS\cwcs33-win-CSCtj01051\CSCtj01051-0>cd ..
D:\Updates\LMS_321_Update\CS\cwcs33-win-CSCtj01051>cd ..
D:\Updates\LMS_321_Update\CS>cd cwcs-win-CSCtg46847-K9
D:\Updates\LMS_321_Update\CS\cwcs-win-CSCtg46847-K9>dir
Volume in drive D is Data
Volume Serial Number is 2CF8-ACB9
Directory of D:\Updates\LMS_321_Update\CS\cwcs-win-CSCtg46847-K9
06/24/2012  11:22 AM    <DIR>          .
06/24/2012  11:22 AM    <DIR>          ..
06/24/2012  11:22 AM    <DIR>          CSCtg46847-0
               0 File(s)              0 bytes
               3 Dir(s)  149,158,404,096 bytes free
D:\Updates\LMS_321_Update\CS\cwcs-win-CSCtg46847-K9>cd CSCtg46847-0
D:\Updates\LMS_321_Update\CS\cwcs-win-CSCtg46847-K9\CSCtg46847-0>d:\ciscoworks\bin\perl CSCtg46847-0.pl
This Point Patch is not intended for this version of cmf.
If you go ahead and Install this patch some functionality of
cmf might malfunction.Please confirm with TAC before applying the patch.
Do you wish to continue (Y/N) [Y] :n
Many thanks
Ian
Vinod Arya
If you are already on LMS 3.2.1 you no need to install that patch. It is already addressed with LMS 3.2.1.
See the release notes for more details (3rd one):
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/SP1/Readme/Readme__LMS_3.2_SP1.html#wp160220
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Many thanks.
Welcome. If this is answered, you can close this thread by mentioning it as answered.
-Thanks
