LMS 4.0.1, all devices are unknown after device update.
andrea.meconi
Level 2
Level 2
Hello.
After successfully install a device update for Common Services, all devices are reported as unknown.
Number of Packages Selected for Install : 2
For Product(s) : Common Services
Install Invoked by user : ameconi
The Package(s) Selected for Install :
Mdf_NonCisco, Mdf
Successfully installed packages (2):
Mdf(1.64) ,Mdf_NonCisco(1.2)
Installation Completed for : Common Services
Any ideas?
When I try to install other updates these fail because MDF is version 1.59.
Thanks.
Andrea
15 Replies 15
Karim.elwardany
Hello Andrea,
i am also facing the same issue and would be pleased if you provide me the file.
