LMS 4.0 Interface Utilization / Monitoring
xcz504d1114
Level 4
Level 4
LMS is not reporting on all of my interfaces, utilization in particular. As an example, I have 1 location that is connected via DMVPN tunnels, when I run a utilization report, it only comes back with information for 1 interface, a random interface, port FA 1/7 on the switch module. If it was all of the switchports it might make more sense.
In DFM device detail the interfaces are being managed.
In the Link Utilization Poller, only 1 interface is listed (FA 1/7).
Any thoughts?
Craig
xcz504d1114
Level 4
Level 4
I created a custom poller, now when i generate the Utilization quick report the Tunnel interfaces are in there. Now the problem is, I will have to do this for 1000+ sites?
hi,
can you help me how to generate tunnel interface in LMS ?
