LMS 4.0 Unresponse Switches Issue.
mkkhan786
Dear Friends,
i have lms 4.0 problem is that some time our switch are not consponding with lms ( unresponse event name shows ) ...when i telnet and check switch, switch not ping to lms ip...after i restart, switch communcate properly with lms ...but after two days again issue raise ...picture is attached kindly provide solution in this ragrds....
Vinod Arya
This doesnt seems like a problem with LMS, it is doing its job it is suppose to do.
If the switch is is having issue, troubleshoot it with switching on why it fails to reach LMS and post this under getting started with LAN or Routing forum.
You need to check, where excatly traffic drops, what issue is there as per switching or routing etc.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
