LMS 4.1 Topology fail
s-putpong
I have HQ and Branch router
HQ       = 2811
Branch = 2801
Connection type Freme-relay between HQ and Branch
CDP enable on interface
The Branch router show in UNCONNECTED DEVICE VIEW of Topology
please solve this problem
Marvin Rhoads
Can you please check and confirm that the devices can see each other via CDP? ("show cdp neighbor" on each device.)
At HQ router show cdp can not see Branch router
At Branch router show cdp can not see HQ router
configure router
HQ
interface GigabitEthernet0/1.1000
bandwidth 512
encapsulation dot1Q 1000
ip address 10.10.191.13 255.255.255.252
Branch
interface Serial0/2/0.1 point-to-point
bandwidth 512
ip address 10.10.191.14 255.255.255.252
frame-relay interface-dlci 16 IET
Well if the routers themselves can't see the neighbors, LMS (which after all only queries the snmp mibs to get its information) certainly won't!
I believe you need to explicitly enable CDP on the FR-facing interfaces of your routers - a global "cdp run" command won't flow down to affect FR interface behavior.
There is also the possibility that your provider won't handle / pass the CDP layer 2 multicasts but first try explicitly adding "cdp enable" on your FR-facing interfaces.
