LMS 4.2.3 Continuous Authentication failure alarm in DFM
Hi All,
We are getting continuous minor alarm[Authentication Failure] for single router in the DFM.  can we check from which ip we are getting the authentication request??
possible steps to find the cause for the authentication failure.?
Channa
10 Replies 10
Vinod Arya
The first row is a alert ID, check what you see when you click on it and share.
Also, please confirm which device is that and what version is it running? Does anything you see on device show log?
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod,
Its 7600 router running below version
IOS : c7600rsp72043-advipservicesk9-mz.122-33.SRE3.bin
Logs on devices:  i can see only below log on the router.
%SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: tool] [Source: <>] [localport: 22] at 00:05:08 IST Sat Oct 11 2014
Channa
Hi Vinod,
I have tried re-adding the device but the alarms are still reflecting on the LMS.
Channa
Please try this, delete device and Shutdown Daemon Manager, then delete NMSROOT/objects/smarts/local/repos/icf/DFM.log. Then restart and readd the device and see if the problem goes away.
-Thanks
Vinod
Hi Vinod,
I will try and update the results.
Channa
Hi Vinod,
i can see two files in the location
DFM.log and DFM1.log - do i need to delete both files or DFM1.log alone ??
Channa
Don't delete, just copy them as a backup to other location. Restart services and give full 10-15 mins and these files should be regenerated.
Vinod
Hi Vinod,
I didn't find the DFM.log file at below location
Find the screenshot
Channa
Please do following:
> stop daemon manager
> Rename/move dfm.rps and dfm1.rps from NMSROOT/objects/smarts/local/repos/icf.
> Move/delete NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log
> start daemon manager
Please monitor the issue.
-Thanks
Vinod
Hi Vinod,
I tried delete the DFM and DFM1.log files. but after stopping the deamon manager.unable to delete DFM1.log as this file was accessed by the smserver.exe in the backend.
i have successful moved both RPS files and DFM.log file from the location. but the issue persists.
I try again to delete DFM1.log file in the MW and update.
Channa
