12-12-2013 01:12 AM
I am trying to create the Fault Notification Group. However, I click on the add it show the following message.
There are no devices in the system (in Known state).
This may be because devices have not been added to DFM, because DFM is in the process of learning about added devices, or because all devices were selected for deletion. Check the Discovery Status page for more information.
| Discovery Status: | Completed |
| Discovery Type: | Custom |
| Discovery Start Time: | Thu Dec 12 10:33:18 SGT 2013 |
| Discovery End Time: | Thu Dec 12 14:18:23 SGT 2013 |
| Total Devices Discovered: | 95 |
| Reachable Devices: | 50 |
| Unreachable Devices: | 45 |
| Devices Newly Added to DCR: | 0 |
| Devices Updated to DCR: | 50 |
I am pretty sure that my discovery has added 50 devices and it is on managed mode.
How to do a further checking on this?
Appreaciate if anyone can guide me. Thank you!
Solved! Go to Solution.
12-12-2013 10:43 PM
Try to Reboot the server and check the issue again.
12-12-2013 07:48 PM
Hi Boon,
Go to
Admin > Collection Settings > Fault > Fault Monitoring Device Administration
check if you have devices there under ALL KNOWN DEVICES under inventory ?
IF above is not the case,share the screen shot of
Admin > Getting Started >Device management.
Thanks-
Afroz
12-12-2013 08:05 PM
Hi Afroz,
Yes. I can see the device in All Known Devices. Is it a cisco bug?
12-12-2013 08:19 PM
Follow the procedure with the database directly and execute SQL commands.
NOTE: please be careful while you run the below commands.
To get the database page please use the URL : http://LMSServerIP:1741/dbreader/dbreader.html
ORhttps://LMSServerIP:443/dbreader/dbreader.html
Their use the following procedure : Username: cmfDBA password: xxxxxxxxx database: cmf
to reset the database password ,if you don't remember it , you can reset it with the
below command:
NMSROOT/CSCOpx/bin>perl dbpasswd.pl all
Execute following commands (one by one and click on Execute SQL Statement) drop table dfmogsgrouppropertiestable drop table dfmogsgroupcachetable drop table dfmogstagtable drop table dfmusergroupassociationtable delete from dbversion where component='DFM' After you drop the above table's restart daemon manager using the following command from the server CMD. Net stop crmdmgtd && net start crmdmgtd
Thanks-
Afroz
[Do rate the useful post]
12-12-2013 08:26 PM
Hi Afroz,
After perform the password reset. What is the default password for the database?
12-12-2013 08:38 PM
default password is
C2kY2k
12-12-2013 10:14 PM
Did the given steps and still having the same issue.
The log from the command you provided.
SQL Statement:
Statement Executed Successfully; Rows affected: 0
SQL Statement:
SQL Statement:
SQL Statement:
SQL Statement:
Statement Executed Successfully; Rows affected: 1
12-12-2013 10:43 PM
12-15-2013 06:06 PM
Hi Afroz,
It is working fine after a reboot. Thank you so much for the help!!
Do you have any best practice guide that I can refer to?
We migrating from LMS 2.6 to new LMS 4.2.4 and I believe there is alots of setting that I not set properly.
