LMS 4.2 - After switch from HTTP to HTTPS, error 403 forbidden access
cminard
Level 3
Level 3
After switch from HTTP to HTTPS mode and reboot, after login, the server (win2008R2) gives me this error:
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I found a previous discussion from this support community :
https://supportforums.cisco.com/message/642678#642678
I checked the LMS services but they seem to be OK (manual/automatic)
I join the files in case :
NMSROOT\MDC\etc\regdaemon.xml
NMSROOT\lib\classpath\ssl.properties and md.properties
What to do to revert to HTTP mode and regain access? And then submit the HTTPS mode successfully ...
Please help.
cminard
Level 3
Level 3
Hi all
Finally, I realized my post is similar to this one :
https://supportforums.cisco.com/message/3563192#3563192
I tried the solution explained in it ...
But no way : my server is stuck in loading state after login, even after back to http mode.
and the server is very very very slow.
Eventually, I uninstalled 4.2 and reinstalled 4.1 ...
Did you get an LMS 4.2 Upgrade license PAK? If so, you must have a support contract - or are you running an eval license?
I see the package is up on cisco.com now and just appeared on the mediuscorp trial download page yesterday.
Hi Marvin
Indeed, I have a 4.1 license and a support contract. Since the upgrade tools do not work for the moment for an upgrade from 4.1 to 4.2, I have a 2 months limited license for 4.2.
But I think my server is not strong enough to support 4.2 (processor) because even just after installing 4.2 (even before discovery), it was very very very slow.
So I revert to 4.1 😞
