LMS 4.2 Syslog File Size and Management
John Mayer
Hello All
i have LMS 4.2 in Network with 100 devices, all of my devices have ACL so, there are too many logs in syslog
after a while the size of the log files in /var/log files (boot.log, messages.log) going to have huge size, something about 20G for each one
I'm looking for a way to reduce the size, is it possible to use Log Rotation or not??
Best Regards
John Mayer
Vinod Arya
Ideall Logs are supposed to fill the syslog file sooner or later. Though logrot is amongst a best way to keep the Syslog file size in check.
You can check the procedure for Logrot here :
Configuring Log Files Rotation
Additionally, there are some more Syslog Administrative Tasks which can keep your syslog in control. You can perform the following Administrative tasks:
•Back up Syslog messages (see Setting the Syslog Backup Policy).
•Purge Syslog messages (see Setting the Syslog Purge Policy).
•Perform a Forced Purge (see Performing a Syslog Forced Purge).
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
