LMS alert
mj11
Level 3
Level 3
I am seeing this error message coming from our core VSS pair's (at different sites) I have checked the syslogs but I am unable to see any interfaces going down on both the 6500's and the connecting edge 4500's. This setup has been fine for around 12 months with no errors and I am just checking to make sure nothing has changed but I don't think anything has.
EVENT ID = 000127G
ALERT ID = 00001G6
TIME = Fri 01-Apr-2011 21:38 BST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = x.x.x.x
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = OperationallyDown::Component=CARD-x.x.x.x/7044 [Chassis 2 X2 Transceiver 10Gbase-SR Te2/2/3-Chassis 2 Transceiver Te2/2/3];ComponentClass=Card;ComponentEventCode=1073;Status=NOTPRESENT;
CUSTOMER IDENTIFICATION = Core
CUSTOMER REVISION = 1
I am seeing more than just a couple of these, the LMS version is 3.2 and the 6500's are running 12.2(33)SXI4.
Any help much Appreciated
Regards MJ
2 Accepted Solutions
AFROJ AHMAD
Hi ,
1. Backup file NMSROOT/objects/smarts/conf/discovery/oid2type_Cisco.conf
2. Stop services
3. Replace the new oid2type_Cisco.conf
4. Start services
5. Delete/re-add VSS devices  from DFM ..
I hope you will not get any false Alarm after this !!!
Thanks--
Afroj
If this post answers your question, please click the "Correct Answer" button"
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi ,
Try Regenerating SSL certificate as below :
-   Stopped the Daemon Manager  :    net stop crmdmgtd
-       Deleted all the server.* files in $CSCOpx/MDC/Apache/conf/SSL
On command Prompt :
-       NMSROOT\CSCOpx\MDC\Apache>perl ConfigSSL.pl -disable
-       NMSROOT\CSCOpx\MDC\Apache>perl ConfigSSL.pl -enable
      Fill all the required information !!!
-       Started the Daemon Manager using  net start crmdmgtd
Thanks--
Afroj
AFROJ AHMAD
Hi ,
2. Stop services
4. Start services
Thanks--
Afroj
Hi Afroj
Thank you for the response, I will try and update.
Regards MJ
Hi Afroj
I can login to the box but when you run ciscoworks I see an error after login to Cisco works..
"403 forbidden"
Do you know how to get round this?
Regards MJ
Hi ,
On command Prompt :
Thanks--
Afroj
