LMS and Cisco ACE Module
tech_trac
Does Cisco LMS 3.0 support Cisco ACE Modules.
Thanks.
Joe Clarke
Yes. See http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/device_support/table/lms30sdt.html . For full support, you may need to add additional devices packages. This can be done through Common Services > Software Center > Device Update. Also, if you are not already on LMS 3.0.1, you should move there first as more device packages are available for that release. LMS 3.0.1 can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .
Joe Clarke
