LMS Disk Space Issue (CSCOpx)
manumohan200
Hi ,
We are using LMS 3.1 .We have totally 50GB space in C drive.But the below folder consumes almost 40 GB .
C:\Program Files\CSCOpx.
Now we have 1 GB only is as free space .
Can anyone please suggest is it possible to reduce the size of the folder or can we take the back up of the same .
LMS version - 3.1
Platform : windows 2003 server .
Intel (R) Xeon (R) CPU .
Regards ,
Sinjish.K
6 Replies 6
Joe Clarke
You will have to be more specific. What files under CSCOpx are taking up the most space?
Hi ,
java_pid1972.hprof - 273,199KB , HPROF file .
Like this 52 files and total consumes 15.9 GB .
Regards ,
Sinjish.K
All of these files can be deleted. They represent crashes in various JVMs.
Joe,
Can we also delete the same files that are under:
C:\Program Files (x86)\CSCOpx\MDC\tomcat\java_pid1784.hprof and others ???
TIA,
Tom
Yes, Hotspot dump files can be deleted.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Is is possible to stop creation of .hprof files in folder C:\Program Files\CSCOpx\MDC\tomcat\?
