LMS Error
subashmbi
Level 4
Level 4
Dear All,
[Fri Aug 14 00:00:00 2009] ERROR(247): D:/backup.LOCK file exists
Most probably another backup process is running
[Fri Aug 14 00:00:00 2009] Backup failed: 2009/08/14 00:00:00
[Sat Aug 15 00:00:00 2009] ERROR(247): D:/backup.LOCK file exists
[Sat Aug 15 00:00:00 2009] Backup failed: 2009/08/15 00:00:00
[Sun Aug 16 00:00:01 2009] ERROR(247): D:/backup.LOCK file exists
[Sun Aug 16 00:00:01 2009] Backup failed: 2009/08/16 00:00:01
Subash.c
I was getting there, but I was hoping perhaps you had a good backup to avoid losing any portal customizations you may have done. In any event, I'm glad it's working.
9 Replies 9
Joe Clarke
You should not do backups to the root of a drive. Create a subdirectory under D:\ (e.g. D:\lmsbkup), and configure that directory to be your backup directory. If backups still fail, post the entire dbbackup.log.
FYI, the bug for not using a root directory for backups is CSCta77845.
Lucien Avramov
Level 11
Level 11
1) On the Windows Services change the CiscoWorks Daemons to manual.
2) Restart the server.
3) Delete the file backup.LOCK
4) Change the CiscoWorks Daemons to automatic.
5) Restart the server and check with a new backup.
Else, attach dbbackup.log file
after i followed these steps, i am getting different error.
HTTP Status 404 - /cwportal/html/cwhp/cwhp.applications.do
This is not a valid URL. How exactly did you launch CiscoWorks? Do you get the portal if you manually enter the URL:
/cwportal/c/portal/login
Hi Clarke,
http://86.36.71.22:1741/cwportal/c/portal/login
after login i am getting these below error Apache Tomcat/5.5.17.
type Status report
message /cwportal/html/cwhp/cwhp.applications.do
description The requested resource (/cwportal/html/cwhp/cwhp.applications.do) is not available.
I am attaching the screenshots.
Subash.c
Did your NMSROOT drive run out of space? Do you have a known good backup available?
Hi clarke,
I followed these below steps,it is working.
1. Stop the daemons:
C:\>net stop crmdmgtd
2. del CSCOpx\MDC\tomcat\webapps\cwportal\db/portal.* d:\ , ( I prefer to move them to another directory out of NMSROOT;)
3. Then copy CSCOpx/MDc/tomcat/webapps/cwportal/db/orig/*
to CSCOpx/MDC/tomcat/webapps/cwportal/db
5. Restart the daemons:
C:\>net start crmdmgtd
Subash
