LMS - Identity Portlet
I'm trying to populate the graphics authentication (portlet). The UT is collecting and CM data too.
In Work Centers > Identity > Dashboard i selected the devices, but the graphic still empty:
I tried to run a report: Work Centers > Identity > Reports (last week) and found some old records and incomplete,
What does not represent the real situation (UT is full data complete: Host IP, hostname, etc). What can be?
I found this log in ut.log:
2012/01/16 10:17:59 main MESSAGE DBConnection: Created new Database connection [hashCode = 3089045]
Calling default
Subnet to SubnetData Map Size :57
2012/01/16 10:18:06 main MESSAGE DCRDevWrapper: Closing DCRProxy
2012/01/16 10:18:08 EvalTask-vmpsadmin-04 ERROR CafAuthSession: snmp value exception com.cisco.nm.lib.snmp.lib.SnmpValueException: Illegal Access. OCTET STRING being accessed as Integer.
2012/01/16 10:18:08 EvalTask-vmpsadmin-04 ERROR EvalPair: java.lang.NullPointerException
at com.cisco.nm.ani.server.vmpsadmin.VmpsAdminSMFGetIdentityInfo.fetchAuthSessionTable(VmpsAdminSMFGetIdentityInfo.java:235)
at com.cisco.nm.ani.server.vmpsadmin.VmpsAdminSMFGetIdentityInfo.apply(VmpsAdminSMFGetIdentityInfo.java:66)
at com.cisco.nm.ani.server.framework.EvalSMFApply.apply(EvalSMFApply.java:101)
at com.cisco.nm.ani.server.frontend.EvalPair.apply(EvalPair.java:108)
at com.cisco.nm.ani.server.frontend.EvalTask.run(EvalTask.java:51)
at java.lang.Thread.run(Thread.java:662)
2012/01/16 10:18:08 EvalTask-vmpsadmin-10 ERROR CafAuthSession: snmp value exception com.cisco.nm.lib.snmp.lib.SnmpValueException: Illegal Access. OCTET STRING being accessed as Integer.
2012/01/16 10:18:08 EvalTask-vmpsadmin-10 ERROR EvalPair: java.lang.NullPointerException
