LMS Login Issues
shahkamrah
I am using LMS 2.6 which is in the setup phase and right now i am facing the issues with the login.I am getting the following error.
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I have checked the services and they are in the following manner
CiscoWorks ANI database engine : Manual
CiscoWorks Daemon Manager : Automatic
CiscoWorks RME NG database engine : Manual
CiscoWorks Tomcat Servlet Engine : Manual
CiscoWorks VisiBroker Smart Agent : Manual
CiscoWorks Web Server : Manual
CWCS Cmf database engine : Manual
CWCS rsh/rcp service : Automatic
CWCS syslog service : Automatic
CWCS tftp service : Automatic
DFM dfmEpm database engine : Manual
DFM dfmInv database engine : Manual
DFM dfmFh database engine : Manual
IPM Aging Server : Automatic
IPM DB Server : Automatic
IPM Naming Server : Automatic
IPM PM Server : Automatic
IPM Stopper : Automatic
I also changed the casuser password ..
I am still not able to login ..Please suggest
Joe Clarke
How did you change the casuser password? There is only one correct way to do this, and that is using NMSROOT\setup\support\resetCasuser.exe. If you changed casuser's password in some other manner, then you will need to run resetCasuser.exe to re-sync the password with dmgtd.
Besides service startup parameters, this problem can be caused by a hostname change, login module problem, or SSL configuration problem. First try running:
NMSROOT\bin\perl NMSROOT\bin\resetLoginModule.pl
If that does not fix the problem, please provide the output of "set" from a DOS command line as well as the NMSROOT\MDC\etc\regdaemon.xml, and the output of pdreg -l Apache while dmgtd is running. Note: if the data in regdaemon.xml is too sensitive to share on a public forum, open a TAC service request with this same information, and TAC can analyze this problem for you.
Thanks a lot for your advice.I tried changing the Casuser password in the same manner and then rebooted the server and it worked fine ..
