LMS on Virtual Machine
ciscoowsc
Is it LMS can work on virtual machine,client installed LMS 3.1 all application on Virtual machine by fulfilling the LMS hardware and software requirement.Am facing issues in LMS such as when clicking on RME Tab it get stucks and sometimes only RME,CM,IPM Tab's are displayed not CS and DFM.sometimes it gives me error unable to retrieve license and sometimes license are properly displayed,On Common services tab devices allocation summary show devices in RME,DFM,IPM,same as they are in DCR but when i go specically on DFM no of devices 0 and also same in IPM.
Does anybody know that it can work on Virtual machine server by fulfilling the cisco requirement(hardware and software) of LMS????
16 Replies 16
Hi Lambay,
U too r in the same boat,though mine DFMServer is the same situation,
lavramov can u help me what are the causes that DFM is not able to cordinate with DCR.
Let's try to reinit the databases:
Stop LMS daemons (net stop crmdmgtd)
remove :
NMSROOT/objects/smarts/local/repos/icf/DFM.rps
NMSROOT/objects/smarts/local/repos/icf/DFM1.rps
Where NMSROOT is the folder where LMS is installed, for example:/Program Files/CSCOpx/
Then run: in NMSROOT\bin:
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
Start the daemons : net start crmdmgtd and import the devices from DCR to DFM.
Logs:
Turn on debugging at : Default Fault Manager->Configuration->Other Configurations-> Logging
the logs are the in NMSROOT/log/dfmlogs/
