LMS - Question
asfar.zaidi
I have a question
Why LMS use uplink IP address for some devices not the VLAN 1 IP?
Regards/Asfar
Joe Clarke
If you mean Discovery is finding devices by "uplink" IP addresses, then that can be controlled in the Discovery settings screen. You can choose the algorithm Discovery users to find the management IP address. This can depend on how you have name resolution configured. If you want the VLAN 1 address to be used, you may need to configure all IP addresses to resolve to the hostname which will then resolve to the IP on VLAN 1.
