LMS3.1 psu problem - Consistency check failed for base package
Mohammed Tolib
Hi all,
I tried to install the following packges for CiscoView 6.1.9:
Rtr2900.cv50.v2-0.zip
Rtr3900.cv50.v2-0.zip
but it gives me the following error:
Consistency check failed for base package NGMARShare
There are no Packages to be installed.
I uninstalled all packages and installed them again after I copied these two packages in the packages sources folder but it failed again.
Any one can help?
the new package you try to install depends on a package that you don't have
DEPENDENT PACKAGE
DtShare V1.5 (DtShare.cv50.v1-5.zip)
this can be seen from the error message you got
"Consistency check failed for base package DtShare"
my advice is to read the "Release Information" for the packages you try to install
you can find the Release Information in the same page of the download.
hope this helps,
also it's better to update all the device packages if your server have internet connectivity from CS > Software Center > device update.
Fadi Twal
the error message is telling you that you need the following dependent package in order to install the ones you have
NGMARShare.cv50.v1-11.zip or later.
so try to install this one and then see how it goes.
the NGMARShare it self may need a dependent package also so you need to read the packages info files in order to know what else you need.
if you face any issue please share the output of
-psuci -p cvw -q -all
-the package you are trying to install.
-the error message you hit.
Thanks a lot Fadi,
NGMARShare.cv50.v1-18.zip has sucessfully installed. After that the two packages
Rtr2900.cv50.v2-0.zip and Rtr3900.cv50.v5-0.zip have been sucessfully installed also.
But when I tried to istall the package Cat3750.cv50.v13-0.zip it gives me the error
although this NGMARShare is the latest version. So what is next?
Attached the output of -psuci -p cvw -q -all
Thanks in advance
DEPENDENT PACKAGE
hope this helps,
Thanks again Fadi.
I sucessfully installed DtShare.cv50.v1-8.zip and NGMARShare.cv50.v1-18.zip. After that I installed three new device packages for CiscoView:
Cat3750.cv50.v13-0.zip, Rtr2900.cv50.v2-0.zip, Rtr3900.cv50.v5-0.zip and everything seem fine.
And yes it is mentioned in the readme file what base package should be installed first but I did not read it carefully.
